NB Miata rear calipers leaking
  • NB Miata rear calipers leaking
    I just finished removing the e brake mechanism from the car and calipers and now the shafts that the emergency brake cable attached to are leaking. I bought a caliper kit from Mazda and replaced both shaft seals, but they're still leaking badly.
    I'm thinking I removed more than I should have? I'm pretty sure I removed the adjuster screws, which is the reason the shaft seals are leaking. Does anyone have any suggestions/wisdom?
    Can we get a picture with an arrow?
    Iirc the adjuster and bolt cover stay.
    The procedure should have been to just rip the guts out of the piston. Everything else can stay. E brake cable can go.
      I picked up two used calipers thanks to Red_5 so I'll just start over. I think what's causing the leak is that I didn't put the adjuster screw back in the piston bore, which has an O ring seal at its base.
        I took these out and didn't put them back. Thus the leak. It should be all better now.
        Click image for larger version  Name:	screw.jpg Views:	1 Size:	372.3 KB ID:	261720
          that will cause a BIG leak!
            Oh, it was a big leak, all right.
              OK, it seems a bit overstated to call this the worldwide debut of Bullet, but this is the worldwide web, so here goes nothing.
                Brett, that is a beautiful Spec Miata. Good luck with her!
                  How are the new Penske shocks that SM has been using?
                  SuperMiata S2 Class #33
                    I'll have to let you know. This car has never seen the track, and I've not yet driven it in anger. They are much higher quality.
                      I don't have them yet on my SM, but I have been told by several drivers that they are a big improvement over the Bilsteins. Sounds like it was a much-needed change.
                        I find it hard to believe you could ever drive in anger...
                          I meant in the Rob Burgoon sense of the phrase.
                            Haha I might have to settle down some with a 99.
                              how much are the Penske? including all the parts that needs to switch out the Bilstein.
