Where can I order new boots for ball joints?
  • Where can I order new boots for ball joints?
    Quick question, rubber boots of my roll center adjuster ball joints are cracked so I need to replace them.
    Where can I get good quality/ price replacement rubber boots? Will the OEM Honda rubber boot fit??
    momofoolio Racing - http://momofoolio.webs.com
    2nd Gen momofoolio Racing Time Attack S2000 - 07 Laguna Blue
    Now Full Time Drift Machine - 93 Silvia 240SX S13 KA24DE"T"
    New Drift Project - 98 LS14
    W2W Companion - 90 NA6 Miata
    Special Thanks: WestEnd Alignment, Rising Star Motors, APR Performance, SportCar Motion, Pit Garage, eXtremeSpeed, PuddyModRacing, Berk Technology & Amsoil
    Forever Missed: 04 G35, 04 Miata, 04 BMW 325ci, 02 S2000, 91 & 98 Nissan 240SX
    Can't Evasive or E-autosports help fix this?
    Do you understand?
      trying to do everything myself nowadays!
      had too much shxt dealing with shops for small jobs so id rather do it myself...
        If the boot is smoke then you are probably better off replacing the whole ball joint. I just replaced them all in my car from good measure since they do wear out.
        AJ - Akua Solutions - #128 Lotus Exige - MonkeyWrench Racing - Carbonetic - Innovative Mounts - Toyo Tires - JRZ Suspension - TW Research Development
          You do em yourself AJ? shoot me a PM if anything, thanks
          Do you understand?
            Yup, didthem the same time I pressed in the monoballs and switched out the steering arm balljoints for heims just a few weeks ago. I do pretty much everything myself. I bought a handy tool to press them out but I don't know if it will work for other cars because it is sized for the lotus armsarms
              its not smoked, just slightly cracked, the condition looks pretty good still...
              can i order the boot from honda?
              mine is tracey sport, but im told its the same joint just different base so honda oem boot can fit...
                Yeah OEM boot will fit. I have a ton of them, but they are so cheap and easy to get from Honda, you should just order directly.
                -Rob
                Check out my '08 build on s2ki.com here....rob.ok track build.
                  -Rob
                  thx a lot for the info rob!!
                  appreciate it =)
