Blackbird Fabworx ND / 124 Fire Extinguisher Kit!
  • Blackbird Fabworx ND / 124 Fire Extinguisher Kit!
    Our new fire extinguisher kit for the 2016-up Miata and 2017-up Fiat 124 Spider is here!
    As usual with Blackbird Fabworx products, the fit and finish of the bracket is top notch with beautiful Pearl Gunmetal Gray powder coat, and all the hardware is top quality.
    The bracket mounts to the two front bolts of the driver seat, just take them out (factory bolts use E12 socket) and replace them with the two supplied bolts and spacers -
    Set the bottle in the distance most comfortable for your sitting position and you're all done
    From top to bottom - front most mounting position, middle position and rearmost position.
    Keep in mind that the hole spacing also give you two more "in between" choices as well -
    There's plenty of clearance under the driver's knees to prevent any type of interference -
    The kit is available in 3 versions -
    1. Bracket and hardware (no bottle) priced at $125.
    2. Same as above but with a motorsport grade 2.5 Lbs. Halotron bottle (as shown) for $255.
    3. Same but with an upgrade to a 2.5 Lbs. Halon bottle (same size, higher rating) for $325.
    The perfect trackday safety upgrade, our ND RZ roll bar and the new fire extinguisher kit
    Send an email to place your order!
