Problem with quoting and editing posts
  • Problem with quoting and editing posts
    Hey Brandon,
    There's some weird issue with quoting and editing posts that I've been running into the last couple of days.
    When you hit "reply with quote" you open the quick reply window and the quote shows just fine, but if you go to "advanced" (in order to add a photo or a hyperlink) the quote will still show in the preview window at the top but not in the actual window that you're writing the post, and if you submit the post the quote will disappear.
    Same goes to editing a post, the preview works but the window with the actual post is blank and if you "save changes" the post will disappear.
    I worked around it with some careful copy-paste in order to do what I needed, but it is very easy to lose quotes or entire posts in the process.
    Hope you're having a good Thanksgiving!
    Originally posted by blackbird View Post
    hey brandon,
    there's some weird issue with quoting and editing posts that i've been running into the last couple of days.
    I worked around it with some careful copy-paste in order to do what i needed, but it is very easy to lose quotes or entire posts in the process.
    Hope you're having a good thanksgiving!
    test test
      Originally posted by ucfbrett View Post
      test test
      TESTING AGAIN
      Blackbird Fabworx RZ ND Miata Roll Bar
        Hmmmm, let me look into this.
          Much appreciated.
